lol just autox'd my column shifted cuda today. no problem, just put it in two, or if your kickdown needs some additional adjustment shift it as needed. This is handy if you want to keep it in 1st for an element so that it doesn't snap in to second the moment you let off the gas. Though i doubt that is necessary on your torquey AAR as much as it is on my 273 that needs carb tuning.
