Quote: If you just want to see if it starts why change out all the points, plugs etc?? YES do this eventually but not at first.. IF it doesn't start THEN start to diagnose....
Why make it hard when it can be easy? They need to be changed anyway, unless you think the plugs and points are good after sitting for 19 years. Why start it to hear it run like sh1t?
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
