Hello all,
Was wondering who uses this ignition box and how it's been for you. I've recently installed nitrous and want the option of having a retard being activated using the box. (I'm not using a trans brake) Was it an easy install and did you have any issues? I recall reading it is only activated above 2000rpm, after sending a signal to the solenoid, correct? Thanks for the input.
