Just thinking out loud......do you suppose I might be able to get away with.....putting down a used set of decals and then spraying the stripes lightly around and over the decals. After the stripes have dried...then removing and replacing with new decals. Just thinking......
Not something I'd do,...but if I did, I'd use the a pair of the same decals (mfg'd) for "masking" as the ones that replace the painted decals, as some mfg's trimming/die cutting of decals is shaped differently, plus I'd put down a black base before "masking" with the decal, because if the decal "shrinks" over time, body color, or whatever base your using might show around the edges?...
