The connector has the ground and hot in it.The pump will run even outside the tank if its connected.You need to check the pump relay and the ASD relay.It should click when key is turned on.Then get a test light and check for power and ground at the pump.Run a long wire from the battery so you know you have good connections.Rocky
Chrysler Firepower
