I run the Nitto NTO5 Drag Radials on my car &I'm very happy with the handling.Mine are 19" rim size so I have a shorter sidewall but if any thing is now faster as you can run 30 PSI on the street(I run 26 PSI Cold in mine)and let them down to 18 PSI if you want to race.Due to running higher air pressure unlike low pressure in a Drag Slick you will not have any problems at 80-90 MPH in curves.If you want Traction the NTO5 Drag Radial is the right choice if its only handling you want the NT555 is best.It said my picture was to big to post so I added a link hopefully for you to see I run them.
<a target="_blank" href="http://imageshack.com/f/ip64aef5j"><img src="http://imagizer.imageshack.us/v2/150x100q90/673/64aef5.jpg" border="0"></a>
