here's something I saw a while back..thought it might work.
A couple of things on this set up.. one, it doesnt have
an expansion points, second I wouldnt run the exhaust
over the valve cover.. just makes more work to get
at the rockers but the car that it goes in makes a
difference
yeah I'm not sure what that was made for. I just like how if you wanted to you could run a full exhaust system, single at that. I'd also like it further away from the valve cover, but if you're running a simple Hydro cam and stock rockers... no harm. Any idea how much power that could support?
