MOOG/PRECISION Part # 295A Greasable Super Strength
At Transmission; RWD
At Center Bearing; RWD
At Rear Axle; RWD
Rear Driveshaft at Support Bearing; 4WD; Crew Cab Pickup; 4 speed trans.; 97.9' bed
Rear Driveshaft at Transmission; 4WD; Crew Cab Pickup; Standard Cab Pickup; 4 speed trans.
Rear Driveshaft at Transmission; 4WD; Crew Cab Pickup; Standard Cab Pickup; 5 speed trans.
Rear Driveshaft at Rear Axle; 4WD; Crew Cab Pickup; Standard Cab Pickup; 5 speed trans.
Rear Driveshaft at Support Bearing; 4WD; Crew Cab Pickup; 5 speed trans.; 97.9' bed
Rear Driveshaft at Rear Axle; 4WD; Crew Cab Pickup; Standard Cab Pickup; 4 speed trans.
Rock Auto, I found my receipt. $19
