Yes, the S-Trac is Strange Engineering's version of the True-Trac. It is available for 3-series Dana 60 and 9" gears only.
So would this option be a better way to go vs a clutch type positraction/suregrip if a person was thinking of having a new differential built??
IMO, it's better if you plan on having a handling based car. Otherwise, the clutch suregrip is perfectly acceptable.
