On a "B" with TTI's I got a stick to clear the headers from Mancini. The only trouble was that it interfered with the power steering hard lines when I installed the engine in the car (E body). It would be worth a try if you don't have PS.
I found the repop stock stick works fine. You do have to remove it to install headers then re-install. Neat, clean and tidy.
