correct me if I am wrong but, I think what he is saying is that the kick down rod came off the lever. And not that the lever came off the valve body shaft....Correct? I'm not sure what the lever would look like for an 89 but it sounds like it had a stud or ball on the end of it... The kick down levers I've seen had the stud on the rod like the drawn picture above.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
