This happens on both sides, not just one or the other. I had been wondering if my axles could be bent or if the bearings are junk - when I got the car the rear end preload was pretty loose (like a good 3/4 inch back and forth). I knocked it back in to spec and it's still in the ballpark a couple years later.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
