What is the sure grip unit ?
Cone type , the axles need to be shorter than stock or you have to remove the thrust block ... easier to trim the axles.
Clutch type, the buttons need to be removed.
If the axles come back out when loosening the retaining plate you are side loading them , but 3/16 to 1/4 " I'd question if they are any good ???
