if it where me and I was at 3400 I would use the low gear set.
Yeah... The car is an all steel nothing removed 71 Duster with bench seat guts that are staying. It's going to have frame connectors, a full tank of gas in the stock tank and a 300 pound driver so it won't be light... Unfortunately.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
