I will tell you what, that would make for one hellofa street car engine at maybe 604 cubes on pump gas!
I think if I ever decide to go a different direction in the Cuda, I might need to try a set of those...
Yes... a street car with 1" of valve lift... you get to start the engine then your springs are junk
