Re: BB Cam bearings, Sealed Power vs Clevite
[Re: ]
#1625973
05/28/14 09:46 PM
05/28/14 09:46 PM
Posts: 485 Central California
MoParFish
Central California
Durabond PDP-17 is the best thing going The std PD-17 is way better than Clevites and others but the PDP-17 is what most builders use--way less trouble than other brands on fitting--they look like they were made by someone that cares --hold up good to rollers etc the ONLY kind I use--have cut down on time wasting tight cams
I had trouble with SP bearings on last build, cam too tight. Tried scraping/shaving and got better but still didn't feel right. Someone recommended Durabond bearings so I removed the other ones and installed Durabond PDP-17s using same tool/method and problem solved with NO scraping whatsoever. Comp solid roller fit perfect.
Entire Thread
Nitrofish
05/28/14 04:28 PM
RAMM
05/28/14 05:57 PM
Nitrofish
05/28/14 06:00 PM
hemiiroc
05/28/14 07:37 PM
CompWedgeEngines
05/28/14 09:03 PM
Nitrofish
05/28/14 09:09 PM
Chris2581
05/28/14 09:34 PM
05/28/14 11:09 PM
MoParFish
05/29/14 01:46 AM
Sport440
05/29/14 03:09 AM
mosweethemi
05/29/14 06:21 AM
rebel
05/29/14 07:18 AM
cl440
05/29/14 03:30 PM
135sohc
05/29/14 06:36 PM
mike s
05/29/14 07:49 PM
