Yes it is TBI, has fuel pressure and injector pulse. No 12V at pos side of coil, and when I hot wire it 12V at Pos. on coil it still has no spark. I couldn't find a crank sensor on this motor, I am thinking it is all controlled by the hall effect sensor in the distributor. Cap and Rotor are both good, Since hot wired new coil isn't putting out spark Im leaning toward something in the distributor.
