YOU DONT HAVE ENOUGH INITIAL TIMING. Hook the vacuum advance to manifold vacuum for the easiest fix.
What is the timing set at, 0 or 5 degrees before TDC?
Now I need to pin those needles, got to feel that heat
Hear my motor screamin while I'm tearin up the street
