thanks rick-i know the green primer you`re talking about-it just seemed odd the brackets were a darker primer than the other parts we found primer on. we are worried about the amount of color that we can`t get under the tray when we paint it all together like the factory did-will it show the correct color primer like the body or should we primer the battery tray separately in a darker grey like the brackets had on them-that`s why i asked if they were installed later as they could have been installed already primed in a different color than the body primer...have i confused everyone yet...maybe i do need more acid
all the best
frank.
