Check out PATC trans site. They have everything you need.
The only thing they can offer him for the swap is a replacement mount & a lock up & OD engaging kit
You use a sledge hammer & a 4lb ironworker hammer & a jack with some 2X4's
there's going to be some serious reconfiguring of the trans tunnel & you can't get that from any website
When you get ready to do it I can give you the step by step easiest way that I've done them so far
My RC the tunnel clears perfectly but it's an 84
You do have to drill new holes in the frame for the correct 518 cross member & braces
Upgrade to a 92-93 Radiator because the 518 uses larger cooling lines If you use the 727 lines which are smaller your trans will drive straight to meltdown
The 727 linkage will work as long as you swap the levers from the 727 to the 518
