Re: New AMD 1970 Cuda rubber bumpers?
[Re: 1972CudaV21]
#1618076
05/10/14 02:03 PM
05/10/14 02:03 PM
Posts: 552 At Your Plymouth Dealers
*440-6BBL*
super gas
super gas
Damn, you can find used ones for less money...
And when you do, few and far between, they're not worth the time to fix them, as the rubber is usually torn, delaminated, deteriorated, or the studs are busted/rusted, which means you have to cut into the rubber to access the other side for welding, and if they're twisted, good luck trying to straighten them without cutting the rubber up even more....
Just dip them in Plastic Dip and you're good...lol..
Man, you really don't have a clue ...
