Quote: Open up heads where pushrods go through. I ran 3/8 pushrods with my Indy 245s
It's not the hole in the heads that is the problem, that I would do no problem. Its the lifter bosses in my block- they are taller as it is a factory roller block, so the clearance is very tight there
