nothing left but the master cyl, take the lines off and see if it releases.
Ordered a new one along with the adjustable brake rod...I just don't get it though..
like cudatom said there is valve for drum brakes in those master cly. either that or you lean so far to the right that it keeps pressure on the brakes
