I have 2 of the Big Block Gold Crane 1.5 roller tip rockers and the pin that holds the roller in is loose. It won't come out but it slides clear to the edge of the rocker. My fear is it will keep working it's way out and then I have a failure. The other 14 don't move at all.
I don't see any clips so I am assuming it is a press fit so would it be possible to repair them??
Maybe install a bigger pin or a longer pin then use a clip to hold it in??
Or just bite the bullet and get some new ones unless I find some good used ones.
What do you engine guys think????
Thanks guys, David
