Auto/stick is available.
Colors, options, etc...can only be "guesstimated."
Colors , options and such will come as PERCENTAGE of all of that particular model built so as stated the number you get will be a "guesstimate" depending on if it is rounded up or down if the number is .5 or below, or .6 and above ...
Careful, you may make someone unhappy.
I mentioned "guesstimate" based on percentages a few months ago in a post where someone wanted a further breakdown. I was called out by a well known member (who I think doesn't own a Mopar) that I was spreading misinformation.
