..... Is there a way to regulate the pressure from the PS pump to the hydraboost unit? I think that is the only way to dial back the assist.
There are pressure regulators made for street rods running PS R&P's, which don't need the pressure that pumps made for steering boxes can provide. Don't know why they don't just adjust the regulator in the pump, but whatever.
In this case I read it as a bias problem, not an excess boost or pressure problem. Did I get it wrong?
I used to swerve around my hallucinations, now I drive right thru them.
