Thanks guys, worked like a charm. Probably the easiest thing I've done on the car in years. Glad I only had a slight pull, sounds like some people have had real nightmares starting up with their arm through the steering wheel.
For future readers, I had to tap the valve toward the rear of the car to correct steering to the left. Not sure if it is a rule or just how mine was acting.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
