Re: Need help with fuel delivery system
[Re: Tommy D]
#1610198
04/25/14 11:25 AM
04/25/14 11:25 AM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
I run this combo in my street car and ran it in our 10.80 ET N/SS car for some time. It was suggested to me by a well-known class racer, and I was told it's good to 10.0's or so. I run a small Carter electric pump (through the 3/8" line). The pump is mounted inside the axle hump, and is out of sight. This combo also uses a small Carter (40 gal per hour) mechanical pump. On the street car, i use only the mechanical pump to drive around town or to shows. I have a toggle for the electric pump which is needed when making all out drag strip passes or pulling a hill. The street car went 11.17 @122.2MPH whith this set up. It's cheap. I've had this system in the car for well over ten years, and I've had no problems. Everyone I tell says it won't work. T
,so can run both?? interesting,hit the electric when needed?
