How does this vent in the cowl of my 37 operate or open up?
if you are asking "does it open from the front or rear"
the front goes up, unless someone made it so it won't open.
there should be a lever under the dash that you push forward to open it, but it all might be rusted up and non working..
I just oil everything up and work it back and forth till it frees up
Thanks, I found the lever, it was hidden by the gauges mounted under the dash. It's frozen so I need to do your oil trick
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
