The CR is not to high,and its perfect to run E85 and even better to run alcohol.I think you would like the alcohol better than the E85 and it would make a lot more torque,more torque=more power/speed with out having to raise the RPM level.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
