Here's a shot looking back twards the tailpanel area...And the biggest tip I've got for you to speed up the process...After the first attempt with the aftermarket splatter paint available today {we've tried a few brands} left us with less than desireable results in coverage especially the darker colors...We now end up leaving the trunk with a gray sealer instead of body color... It really cuts down on the material needed for the coverage...Then blend the "edges" of the splatter paint into the body color...
