Just can't read the date code for anything. Oh well, doesn't really matter, I guess.
I did make another discovery today when I was out in the garage playing around. The diff has a 3.23 tag, but thought I'd make sure. Well, it is 3.23, but when I turned one side to count the turns, I found that the other axle was turning in the same direction! I was surprised, because I thought that if it was SG, the tag should say 3.23 S (it just says 3.23). Is that right? If so, hope I don't find a nasty surprise inside.
