I appreciate you looking. It does air check good. I have never had a problem like this before. It is a LBA trans-brake now, so I will have to press button for reverse to engage. The old brake is a JMH brand. That is what is engraved on the cover. Has anyone heard of them? Thanks for the help. Mike
From my understanding the LBA brakes you press the
button for reverse... you might call the brake comp
and ask and should it be in reverse or neutral
