Quote: Easier.. yes. But I got the bell dirt cheap. I figured it can't be all be that hard to bore one cast iron hole bigger? How much could that cost?
One thing you need to check is the location of the throwout bearing pivot , take a measurement and make sure the bolts that hole it aren't too close to your new hole .
Also they make the retainer you are trying to turn that into , but it's cheaper to turn it down.
