Can't you just get another rubber hanger?
Yes, I actually have enough of the strap to just cut off the broken part and use more, but the hanger was only on the car for a few months and less than 100 miles and it already gave out. I should probably have more than one hanging point (per side) in the back.
If the only exhaust system movement needed is for heat expansion, then I might double one of those rubber straps over and use it on a very short section.
