supposedly, you can use the hyperpac on the old vehicle, and restore all settings to factory. this "unlocks" the hyperpac, and allows you to use it on another ride. the vin is locked into the hyperpac, when you program a ride with it, and the only way to go back to the beginning, is to restore your first ride, to a factory setup.
"When Tyranny Becomes Law, Rebellion Becomes Duty"
