Here is one for the experts.
I have a friend with a 1966 Barracuda and the horn does not work. We have chased the problem down to the fact that there is no ground between the steering column center shaft and the gear box. Does anyone know if JB weld has conductivity? The plan would be to put a spot of JB weld on the spline to coupler connection to make a ground.
Thoughts?????
Thanks for any help in advance.
