Replaced my 318 in my 74 challenger with a 340. Put a Edelbrock manifold and carb. on, but it seems the throttle cable distance is too short, it won't reach using the 318 throttle cable bracket...etc. Is there a special bracket for that?
You may need one of these to make it work with your 318 bracket?
It bolts to your 318 bracket and relocates the mounting position.
