I've done it both ways. Socket is much better. If you have to buy one do it. You probably have other Mopar buddies. You can get your money back by renting it to them for a small fee. Keep the amount small; you'll keep your friends and still come out OK. Keep the control arm on the car and use an impact wrench for removal. Installation torque is 125 ft.lbs. minimum. I usually go 150 ft.lbs.
