Check the spring perch it could be ripping free or
the right spring is shot in the front allowing it
to flex alot... the front holds the axle in place and
gives it the lift... the rear of the spring is what
holds it up... if it started sorta quick I would look
at the perch first... also is this a dana rear end..
the tube can be rotating in the housing
