Rb block...512" eagle stroker kit
11:1 compression
440 ez-1 max wedge heads
Eddy super victor max wedge intake
1050 dominator
Comp solid roller...625" and 275 @ .050
Harland sharps 1.5
2" headers
Through a hemi 4 speed.
Motor is sitting ready to be installed in my 67 plymouth...can't wait to see what kind of power it makes. Thoughts?!?!
My guess is at least 700 hp. Its kinda like a big brother to my eng as mine is the 440/493 combo with the 4.15 crank. I have the basic EZ heads that use the standard rockers (no offset with the standard exh port location) and I bought them from Dwayne Porter who just cleaned them up some.
10.6 comp with dished pistons and quench to run 92 pump , the Indy dual plane intake and an 850 DP carb. Solid flat tappet cam , 2" TTI headers with the full 3" exh with X-pipe. I believe I make about 600 flywheel hp by my 10.70's @ 3700 lbs and I have really never flogged it hard other then jetting so if I ever take time for serious tunning it may be some more there. Yours should make a good bit more then mine as thats why I think your good for at least 700hp. Good luck with it. Ron
