il will take a look and see ..its worth that but I have changed the fuild and filters in this thing about 8 times and always the same end results... this time I will look at the mounting points and make sure cause I never have thought of it cracking or losing the seal ..and most the filters have a plastic pc that it use to mount on with as well..thanks
