I suppose you're right Mr P. As long as you use that gauge on your car all the time and get the same reading regardless of accuracy you will have the same results vs using different gauges that may all display different readings.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
