I bought this car off Hudson late last fall and have been making a bit of progress between waiting for parts and other issues. Car is an original matching #'s 340, 4 speed, axle pkg car. A few slight modifications will be made to better performance however I think the only holes that will be drilled will be to install the factory rear sway bar. I bought the car as a painted shell but with almost all the parts to complete it. I had a slight mishap bringing the car home from Seattle and this is a shot of the car coming back from the bodyshop after the damage to the rear stripe on the trunklid and quarter had been repaired. I had made the car rolling at this point obviously.
