I changed engines in my '85 W-150 a while back, before I took it apart there were 2 wires attached to the negative side of the coil. Both are black with yellow tracers. There is no tach in the truck. I only have one of those negative wires hooked up right now, and the truck runs but I'm wondering what the other wire could be for? I have a miss I'm trying to track down.
