I broke down and bought a set of bare heads and their valve train set of the new Pro Comp LA heads. The flow numbers are pretty decent and comparable, if not better than the Edelbrocks. I have a whopping $730 in these heads and couldn't be happier with the quality. The service on the other hand was really lacking. They sent the wrong spring cups and had to call 10 times to get the correct ones. I know I'm going to get some response back about them being "Made in China" but anyways here are the flow numbers OOTB with 2.05/1.60 valves. They are right in line with my ported RHS magnum heads.
@28"
Lift INT EXH
.100 69.5 63.1
.200 130.4 103.4
.300 182.6 139.4
.400 227.5 164.2
.500 245.7 175.3
.600 252.3 180.2
Making sure I am reading this correctly, but your PORTED RHS heads, wont outflow these numbers you have posted? They SHOULD crush those numbers, but maybe I am not understanding something here...
Blew those #"s away with a set of home ported 2.02 / 1.60 915 LA castings.
Fastest 300
