The fan I use my air chisel to loosen.Just get it on a flat and bump it.Once loose they spin off.On install I just reverse taking them off.Did hundreds at work that way.Nothing on the ring to seal it.I use a bit of grease to make sure they dont move on install.Just scrape any crud off before the install.Rocky
Chrysler Firepower
