Re: new build, oil in the coolant,
[Re: dvw]
#1586811
03/02/14 05:23 PM
03/02/14 05:23 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Update. The heads are new and held pressure. Then we aired up the block through the rear ports that feed the heads. It doesn't hold. No apparent external leaks. The rivets were removed as the gaskets were disassembled an sprayed. The motors coming out this afternoon. Pressure added to the cooling system forces oil from the oil feeds. There also appears to be some coolant in the oil. Doug
There is no way that the motor will hold air pressure through the oil system, bearing clearances, lifter clearances, blowing the oil back through the pump and filter into the pan and so on That might be a way to find the leak though, look and feel for the escaping air
Entire Thread
new build, oil in the coolant, UPDATE
dvw
03/02/14 03:56 AM
Cab_Burge
03/02/14 05:23 AM
dvw
03/02/14 06:04 AM
Crizila
03/02/14 05:39 AM
rbj
03/02/14 06:06 AM
Cab_Burge
03/02/14 09:54 AM
rbj
03/02/14 02:55 PM
rbj
03/02/14 03:50 PM
Wv68charger
03/02/14 04:14 PM
MR_P_BODY
03/02/14 04:26 PM
fbs63
03/02/14 04:30 PM
70satelliteguy
03/02/14 06:27 PM
dvw
03/02/14 07:25 PM
wyoming
03/02/14 08:46 PM
68roadrunner
03/02/14 09:17 PM
Cab_Burge
03/02/14 09:23 PM
dizuster
03/02/14 11:13 PM
Re: new build, oil in the coolant, UPDATE leak found
dvw
03/03/14 01:39 AM
Cab_Burge
03/03/14 02:29 AM
rbj
03/03/14 03:06 AM
HardcoreB
03/04/14 03:39 AM
rbj
03/04/14 06:37 AM
BIG BEAR
03/19/14 05:47 PM
