I also added a rear floor support for the centered rear body mount and it will be tied into the cage. All but two of the body mounts will be tied into the cage. There isn't a lot of room to run "frame tie-ins" so I decided to have the body mounts play double duty. Each has a 1/2" bolt, six total.
