Its just that you powered down the central timer module. I had a few trucks over the years come in with the timer module locked and once I unhooked it from power and woke it back up it worked fine. Part of the security system and it will lock like that sometimes. And I never replaced the central timer module for it and none have ever come back. I was going to replace the first central timer module on the first truck it happened to but Mopar tech line told me not too so I did not. And as I said I have not had any comeback saying it happened any more. The start and stalls tells me yours was stuck in the security on mode. You should be good now. Ron
